Up Topic Welding Industry / General Welding Discussion / classic III
- - By Classic III Date 05-16-2008 05:57
I got a 1997 Classic III my battery keeps on going dead i noticed that the clock stays counting in the off position any ideas why its doing that  thanks
Parent - - By KSellon (****) Date 05-16-2008 12:54
your engine protection switch box is staying engaged. The contact points are probably carboned up. Disassemble the box and clean the points with emery cloth, reassemble.
Parent - - By Classic III Date 05-16-2008 22:54
Okay i did that and its still doing it any other ideas
Parent - By Justin O (**) Date 05-18-2008 08:49
buy a miller lol
Parent - - By KSellon (****) Date 05-19-2008 12:50 Edited 05-19-2008 13:01
WHAT IS YOU CODE#? Wire 58 off the hour meter runs to the "NC" terminal of the engine protection relay, wire 60 runs to common ground. Check your ignition switch.
Attachment: classic3D001.jpg (0B)
Parent - - By Classic III Date 05-20-2008 06:01
NO THE SWITCH WORKS FINE
Parent - - By Classic III Date 05-20-2008 06:07
YOU THINK THAT IT MAYBE THE PROTECTOR BOX BECAUSE IT LOOKS LIKE ITS BEEN TAMPERED WITH OTHER THAN THAT THE MACHINE RUNS LIKE A CHAMP
Parent - - By KSellon (****) Date 05-20-2008 20:29 Edited 05-20-2008 21:12
Lincoln part number S16897 (Murphy part number 761APH6012) when you took the cover off the box did the contact points (that you cleaned) or any of the internals look damaged?
Parent - - By Classic III Date 05-21-2008 03:38
NO IT ACTUALLY LOOK PRETTY NEW THE ONLY THING I NOTICE WAS ONE OF THE LITTLE TERMINALS THAT COME OUT OF THE BOX HAD A SCREW HOLDING IT IN PLACE INSTEAD OF A RIVET THAT HOW I KNEW SOMEBODY HAD ALREADY MESS WITH IT
Parent - By Billyjoe (***) Date 05-22-2008 03:51
Call Bill's welding repair in OK , City they have nice lady that can help you in just a few min.
