I'm kind of confused on how I'm going to qualify a tig dressing WPS under sec 4 of AWS D1.1. I'll try to describe the joints we dress with the TIG. Coming up off of the 2 base beams of the ladder running down the full length, you have T-K-Y small square tubing fillet welds acting as the hand rail supports welded with ER80S-D2 GMAW wire. You also have thin round tubing connecting the 2 beams acting as the rungs of the ladder welded also with GMAW. We mostly dress cold lap issues and undercut using GTAW with ER80S-D2 filler. I guess what I'm confused about is you really are welding three different base materials, A607gr60 for the base beam, ER80S-D2 as the filler and probably A500 for the sqaure tubing. When dressing a toe you're either welding the A607gr60 to the ER80S-D2 or the A500 sqaure tubing to the ER80S-D2. How do you qualify that? Are ya smellin what I'm cookin here?
What do you guys think the easiest way to go about qualifying this GTAW WPS would be. I'm probably making it out to be a lot harder then it really is, but I figured some input from the pro's would be a great learning experience. Keep in mind that everything on this ladder is thinner than an 1/8" which is supposed to be out of D1.1 territory, but I was told I could still use it.
Thanks, Ray
