Up Topic Welding Industry / Technical Discussions / Does 6063 turn into 6061?
- - By devo (***) Date 05-20-2008 18:15
I was just reading a boatbuilding forum and someone said that 6063 T-6 will "age" into 6061 in less than 14 months.  Is this misinformation?  Are the mechanical properties such that 6063 T-6 improves over time?
Parent - By Lawrence (*****) Date 05-20-2008 18:48
6061 contains     0.60 Si        0.28 Cu       1.0 Mg        0.20 Cr
6063 contains     0.40 Si        0.    Cu        0.7 Mg        0.   Cr
I don't see how aging any amount of time can change constituants.
Parent - By DaveBoyer (*****) Date 05-21-2008 04:53
   devo: A friend of Mine who bends 6061 aluminum tells Me that  6061 T-4 can be bent when You first get it, but over time it ages and becomes more brittle, more like T-6, and can't be formed sa much as He needs to form it. I am not really familliar with 6063 alloys, but if the mentioned alloy ages and becomes more brittle, that may be what the author is trying to describe.
   I have to agree with Lawrence that the actual alloy is not likely to change with time, but the temper and formability might.
