Up Topic Welding Industry / Technical Discussions / Full-depth partial penetration weld
- - By Stevenp Date 05-22-2008 20:00
Can anyone explain what "full-depth partial pentration" is ? This is specified in FEMA 350 for seismic moment connection weld although the symbol shows it as a CJP weld with a reinforcing fillet. Thanx!!
Parent - - By hogan (****) Date 05-22-2008 20:40
if you are referring to figure 3.8 and 3.11 then i think it is a partial pen weld that is detailed as full depth/thickness but not considered a cjp. This will change some code requirements for that weld.
Parent - - By Stevenp Date 05-22-2008 23:00
There is no reference to D1.1 (this is FEMA 350), but it's per Fig. 3.3 , Joint BTC-P4, except instead of showing depth of partial pen weld, a note says "full-depth partial penetration from far side" ! Anyway I am treating it as a full pen weld. Thanks.
Parent - - By hogan (****) Date 05-27-2008 14:11
the reference was FEMA 350
Parent - - By Stevenp Date 05-29-2008 00:21
Thanks again...yes I checked it against FEMA 350. After back-gouging, a couple of such welds in the field were found to only have 3/16"  penetration (on a 3/8" plate). The contractor is fixing all welds.
Parent - By hogan (****) Date 05-29-2008 13:06
that seems difficult to do with proper bevel prep
