You could try K&M Manufacturing in Cassopolis - S/W Lower in the boondocks. They do heavy fab. Were looking for a welding engineer. May always have a need for welders. I did not want to live in the boondocks as a single person, so they told me to find Chicago.
not knowing specifically what type of work you're looking for...
I'm from Ann Arbor and obtained an AAS in welding and fabrication from WCC. I worked as a welder in several small shops around the area as well as a shop in detroit. From my experience there actually are a decent amount of work in the area. When people think south east michigan than think detroit auto. but that's not the only work. Ann Arbor has an abundance of small research, specialty and technical companies. This is probably due to the abundance of brain power radiating from Uof M. I worked briefly for a small engineering consulting company and job shop. There was a lot of work coming from these small companies.
outside a few cities, ann arbor, grand rapids, traverse city (okay that's not lower michigan) the economy is declining. However as most of us know or assume there's a shortage of skilled welders and welding engineers. I had no problem finding work.
The work is there, but the state economy is at the state of collapse thanks to the flounderings of detroit auto.
What brings you to southern michigan?
