Jim,
Thanks
Interesting though. They did indeed limit it to those alloys susceptible to temper embrittlment or heat treat cracking, which in my opinion is a good thing, and consistent with the conservatism of ASME, but I noticed in your quote (and I know your quote is a limited extraction), it does not say which NDE specifically. Is this included in the remaining paragraph? Is it left up to the specifying party, the fabricator, or is the code silent on this point?
After all 31.3 has had hardness testing (an NDE method)after PWHT in place for some time. For the purpose of verifying PWHT. This is not what is a concern in the context of the original post. P1 is conspicuously absent.
I gotta get my hands on a more recent version of 31.1.
Also, the NDE of choice for concerns about temper embrittlement and heat treat cracking of bainitic and martensitic materials (the materials listed in the orginal post) has been RT.
So UT would of course be of great value. Perhaps even more so. PT, MT, hardness testing are almost useless for the concerns involving the materials in the above posted paragraph and the original context.
And I also noticed the 'Engineering" "exception" at the end which almost renders the paragraph a recommendation. In other words, you have to do this, unless you don't wanna.
If you have concerns specific to Grade 91's, Grade 92's, and other CrMo's, or low alloys, just saying NDE ain't gonna get it done. You need RT/UT.
So clearly I've even corrected myself on the NDE after PWHT recognizing 31.3 hardnesses, I was assuming RT or UT due to the alloys the original question was framed around.
