Hello Chris, actually "some" of Millers feeders do have the in/min. designation on them, but like so many other makes of feeders this can vary widely. Power sources can go the same way, look at the older Powcons for instance, they used a 1 to 10 designation for voltages or amps depending on mode and model of machine. There are plenty of machines that technically cannot be "calibrated" in a sense as they are not equipped with readouts or analog scales. You may "consider" posting a legend to give a bit of a breakdown on approx. wire speeds at particular points on the 1 to 10 scale, this may be enough to satisfy your audit requirements. Just a bit more to ponder. Best regards, Allan
