Dear you all,
When I read ASME II Part-C Specification A5.1 Table 4 I found some confusion as below:
- At table 4 given some required tests, E7016 Electrode with diameter 2.4, 2.5, 3.2 Not required for Chemical Analysis, so may I ask you all that, when we buy E7016 the manufacturer don't need analysis chemical? It mean that I have one certificate for E7016 without chemical analysis then the certificate is valid or not?
