Yes, the H8 indicates that it is low hydrogen. When doing a PQR you can use what ever filler you want as long as the mechanicals come out within the code criteria I'm pretty sure. The low hy wire will be good when welding to the A514. There are a lot of low hydrogen FCAW wires on the market and some might be cheaper then the one you suggested. Who makes that wire?
