Up Topic Welding Industry / General Welding Discussion / pipeliner electrode holder
- - By K.Sexton82 (*) Date 06-04-2008 05:44
trying to find out what kinda electrode holder pipeline welders use .it seems to me they all use a specific one,could someone tell me were to get one on the net thanks.
Parent - - By Kix (****) Date 06-04-2008 12:42
Use one that works for you. Since time is money, use a 200amp clamp style not the twisty style.  Again, it's all user preference.
Parent - - By sbcmweb (****) Date 06-04-2008 18:10
TwecoTong: 200-300 amp. You can bend that rod to suit you any way you want it. The twist ones are too expensive & moving parts to break inside. Couldn't ever get used to them either.  My 2 cents anyways. :-) S.W.
"I knew a guy that had a car like that once. The f***i'n bastard killed himself in it. The son of a b***h was so mean, you could have poured boiling water down his throat and he would have pissed ice cubes." (Will Darnell to Dennis Guilder. Christine)
Parent - By K.Sexton82 (*) Date 06-04-2008 21:00
thanks guys for the info im fimilar with tweco and lencos 250 amp models its a different brand then those they have a destinct look like the jaws are uninsulted they are very narrow and look kinda around 300 amp model not sure. im sure there insulated just looks that way
Parent - - By 52lincoln (***) Date 06-04-2008 21:24
must of the ones i see around here are lincoln t300 electrode holders.beware they dont have no insulation on them
Parent - - By Billyjoe (***) Date 06-04-2008 23:15
get one that you can get mad at,,an take it an beat the h**** out of it an have money you can buy a new one just like it . goog old stinger
Parent - - By Cactusthewelder (*****) Date 06-05-2008 00:55
Try a DURO holder. I used one about 10 years ago and still use them now. They are a tong type holder
Parent - - By pipeliner04 (**) Date 06-05-2008 04:08
pipeliners use what is call a T300 as stated above.  to be honest with you for what reason i dont know.  I use a tweeco 200 amp because i have little hand and when your gloves and your legs get sweaty,,and your knees on the ground,,that damn T300 with no insulators will lite your ass up on occasion.  i cant use em,,,ive tried,,,the springs wear out to quick from heat.  to each his own,,,i just prefer comfort over looks andyday,,but regardless,,,it aint what ya got its how you use it
Parent - - By K.Sexton82 (*) Date 06-05-2008 04:57
thanks guys like i said just curious for piece of mind . i use a lenco thats what works for me
Parent - - By K.Sexton82 (*) Date 06-05-2008 06:43
why do they take the insulators off it comes with some on it?
Parent - - By fordsux8269 (**) Date 06-05-2008 21:51
Here is what you are referring to But I dont know what brand they are. The one in the bottom left corner
Parent - - By 52lincoln (***) Date 06-05-2008 21:52
lincoln t300
Parent - - By K.Sexton82 (*) Date 06-06-2008 03:50
52lincoln i found a lincoln t300 on northstate pipeline supply and it looked totally different then the one posted above it had insulators own it and looked quite bit shorter than that the handle was different to
Parent - - By 52lincoln (***) Date 06-06-2008 04:22
thats the only one i've ever seen
Parent - - By K.Sexton82 (*) Date 06-06-2008 05:10
it is a lincoln LT 300
Parent - - By 52lincoln (***) Date 06-06-2008 21:08
i use the one on the left.when i get them i say lincoln t300. that is what i get
Parent - - By okwelder82 (***) Date 06-07-2008 02:25
How much are those Lincoln T300's
Parent - - By cpopham (*) Date 06-07-2008 05:10
About 25.00$ in Texas.
Parent - - By fordsux8269 (**) Date 06-07-2008 21:51
Where is everyone buying these at?
Parent - - By 52lincoln (***) Date 06-07-2008 23:56
welders warehouse Waxahachie  TX
Parent - - By ibeweldingsum (***) Date 06-08-2008 00:28
mine r company supplied and r so long 2 get ur hans outa da fire so 2 speek gotta tweek em for yur own comfort
Parent - - By Stringer (***) Date 06-08-2008 00:37
I'm told the Lincoln t-300 is chosen for durability and price, but it seems to me that one big inadvertent arc strike is going to cost a bucketfull of Twecos somewhere down the line.
Parent - By ibeweldingsum (***) Date 06-08-2008 01:22
yeah u gotta be mindful at all times where that thing is hangin kinda like yur johnson so 2 speek :)
Parent - - By shorthood55 (*) Date 06-08-2008 15:53
The T-300 doesn't come with insulators.
Parent - - By Root Pass (***) Date 06-09-2008 23:37
here is a pic
Parent - - By ZCat (***) Date 06-10-2008 00:22
I never could figger out why they use those. I'm used to laying the stinger on the pipe when I take a break, you can't do that with those. Seems l;ike they're so paranoid about arc strikes they wouldn't touch 'em. Must be a tradition thing. Same with pancake hoods, first time I got a spark on my lip that thing was history.
Parent - By Root Pass (***) Date 06-10-2008 01:19 Edited 06-10-2008 01:21
I think the pancake is great but I think these make a better ground than rod holder! Here's a pic from the forum.
