Up Topic Welding Industry / Processes / What Cloth Do You Use When Wiping The Tining Process ?
- - By SCHOONER (*) Date 06-06-2008 02:46
Hi Guys
I'm kinda new at working with Lead Free Body Solder.
Tell me what I'm NOT doing RIGHT.
TINING PROCESS I DO;
1. I made sure the surface of the sheet metal is nice and clean: Disc Sander and wipe it down with ACTONE.
2. I get me tining paste and brush in on followed by heat.
3. Once I see the tining paste turning BROWNISH, I now use either one of these wiping cloths or paper towels. I wet 'em donw first and then hit the tining area.
4. Sometimes I use a piece of terry cloth towel.
Note: I bought cheese cloth; haven't use that YET.
Questions Please:
1. What is the proper wiping cloth should I be using ?
2. Is their a special tining cloth that I can buy ?
3. Does the tining cloth have to be dunk in " Hot Water " and then wipe the tining area ?
I'm in your hands guys. I will follow your LEAD . . . LOL  or  SUGGESTIONS.
THANK YOU ALL
GOD BLESS
SCHOONER
Parent - By Tomwalz (*) Date 06-06-2008 16:44
In sweating copper you use a cold cloth or sponge to set the solder and control the flow.  Othwerwise the solder in a copper joint will run  down.  Any thick cloth will do.
Is this at all helpful?
You might try the Practical machinist forum.   Lots more hands on advice.
http://www.practicalmachinist.com/
Tom
