Relay sticking, malfunctioning safety component, or totally shot relay for the safety circuit. Cycle power, if that does not get it, check the light screens or floor mats for proper function. If still having problems, check the auto stop led's in the right rear of the upper cabinet attached to the right side. You should see two led's for each half of the circuit. If you only have 1, it's not going to function. Try to locate the two relays that control the safety circuit and test/ replace.
