Up Topic Welding Industry / Technical Discussions / welding A455 steel
- - By edward jones Date 06-09-2008 03:08
I need to make some modification to an old chemical pressure tank rated at 250 psi. it will be used as an air tank at a working pressure of 125psi.
It is about 5/16th thick  in good shape and rust free. I have been unable to find any recommended procedures or precautions for this material. a welding supply store recommended using rod LH8018C3MR, but that was all the info they had. Anyone having any experience with this alloy?
Parent - By ravi theCobra (**) Date 06-10-2008 22:05
If  you are going  to  use this  @  125  PSIG   then  you  damn  well better  have  an  "  R  "  stamp  to  document  the repair  and  re -  hydro  -
