What process are you using? SMAW, FCAW
If so they may fall under the pre-qualified filet welds in D1.1 and you can use that.
D1.1 does have a chart that calls for a minimum fillet weld all around depending on the diamater of the stud. I think it's section 7? but you'll have to check me on that.
Chris
