My problem is penetration and fusion with short circuit transfer on 1/8" 3cr12 stainless using .035" 308lsi wire. We're using 2 different gasses ( trimix 90%helium-7.5%argon-2.5%co2) and (98/2 98%argon-2%co2). Penetration profiles between the two gasses are very similar with incosistent penetration to the root and lack of fusion outside on the legs. Positions are 2F, 3F vertical down, and 4F. I got the 2F and 4F to pass barely and the vertical down is giving me hell.
Parameter for Trimix are ruffly 22.0v and 290-300 IPM somewhere around 150 amps. Parameters for the 98/2 are 18.5v -19.0v 350 IPM. Note the IPM changes between the two gasses. This was done with 2 different Miller 350p's and both have supposively been calibrated. I don't know if this is a characteristic of the base material because of how hard it is or what. Any tips or tricks or comments welcome!
Thanks, Ray C.
