I'm just checking to see if you need to qualify the base material and wire to sec 4 before you can qualify a fillet weld WPS with the same material. I'm pretty sure you do, but I wanted to be clear because I'm having probs finding the clause in the big red book right now. I've allready got the base material qualified with a lower strength wire and had to qualify a WPS for an GMAW automatic 1F fillet with 3 macro's on 1" thick plate. Come to find out were using a 110ksi wire for the automatic seamer when the PQR's I did were with 90ksi wire. So do I need to set up another groove plate and lay some of this 110ksi wire in there with the seamer to get some tensiles, bends, and RT? If I do, I'm going to go to the EOR and ask him if I can drop down to 90ksi wire for the outriggers.
