anyone here use solid works or auto cad to detail welds? got a problem in solid works, namely there is no edge joint symbol. The engineer who uses solid works said, "I can't detail them, I'll just use a V-groove instead". why he decided on a vgroove for an outside corner fuse weld I don't know, but I'm hoping someone has a solution. I made up a file of custom blocks in auto cad so that wasn't as bad. Any clue I did a google search and only came up with a question on a forum asking the same thing with no solution.
Wouldn't be a big deal but about 50% of our GTAW is outside corner fuse welds and I detail them with an edge weld with melt thru. tired of seeing v-groove and every other imaginable symbol applied to an outside corner.
solidworks 2007 for the record.
