Please read AWS D1.1:2006, Table 6.1(8) very carefully and then look at the question again.....that verbage in that Table 6.1 will answer your question.
Remember to use the correct column of the chart that applies to the question. The shaded boxes mean that it does not apply to certain types of connections(see the Note at the bottom of the table).
Good Luck
BTW, the sum of porosity means that you add them up.....ie. 3 pores measures 1/8" each = 3/8"
