I am not on the latest trends in high end welding. As far as ASME Boiler and Pressure Vessel Code goes, there is no requirement for "Certifying" a machine. In some cases there may not even be a requirement for calibration of a gage. Below is an interpretation clarifying what appears to be a conflict between section IX and section III.
The word "Calibration" or "Calibrate" is never used in D1.1 except in reference to Ultrasonic testing. It is not used in ASME Sec IX. However that does not mean the use of a calibrated instrument is a bad idea. The term certified in relation to a welding machine is never referred to in D1.1 Sec IX, Sec I, Sec VII, B31.1.
By whatever method you control the welding process is what you should do. Just be careful on how detailed you get. A ammeter and voltmeter may be all y ou need.
Here is a page I made with a couple of code interpretations with the word calibrate in them. Some interesting reading.
http://www.weldinginspectionsvcs.com/requirement_for_calibrated_weldi.htm I would love to hear some other input on the "code requirements" for calibrating a machine.
See also
http://www.aws.org/cgi-bin/mwf/topic_show.pl?pid=63297http://www.aws.org/cgi-bin/mwf/topic_show.pl?pid=32645http://www.aws.org/cgi-bin/mwf/topic_show.pl?pid=18419You nuclear guys, is there a requirement to have calibrated gage on a welding machine ? does each weld being made have to have the amperage and voltage recorded ?
