Up Topic Welding Industry / Technical Discussions / T91 weld to TP316
- - By dragon (**) Date 06-30-2008 12:51
anyone have welded this type joint?
Parent - - By 3.1 Inspector Date 06-30-2008 12:55
No, but P91 to TP347 - its no problem.
Parent - - By dragon (**) Date 06-30-2008 13:04
what welding material do you use? and pwht?
Parent - - By 3.1 Inspector Date 06-30-2008 13:06
I cant remember the filler material designation.
Yes - both preheat and PWHT must be done.
Parent - - By js55 (*****) Date 06-30-2008 13:34
A nickel base alloy is preferrable (Alloy 625 is common) so that the thermal expansion matches the Grade 91 side more closely placing most of the thermal strain on the more ductile austenitic joint between the nickel and the SS (same reason you switch to nickels from 309 in higher temp applications for more common dissimilars between austenitics and ferritics/bainitics) .
There are also some special EPRI chemistries available specifically designed for Grade 91 to austenitics such as 347.
Give the guys at Euroweld a call. They pretty much know more about this stuff than anybody between the oceans.
Parent - By dragon (**) Date 07-04-2008 03:33
thanks! Nickel base alloy is preferrable. In EPRI, not permit use alloy 625.
