Can you check the depth of penetration on a aluminum weldment of 2"X 4" square tubing welded on both sides of 4"X 4"X .375 thick plate by RT are do you need to DT to find it. MG
By 3.1 Inspector
Date 06-30-2008 21:03
Depth of penetration can be checked by RT - a so called on stream technique must be used.(someone might correct me on this one) Not sure what you mean by DT?
