This is new & much more advanced. I received special seminar training from Billy Mays HIMSELF! He instructed me to first use Oxy Clean & Kaboom to sanitize the surface. Then, using the Awesome Auger to grind the porosity out, The Samurai Shark will sharpen the blades if they get a little dull. Since the pipes will be hung with Hercules Hooks, no further rigging is necessary. Use the Handy Switch to turn on the welder, activate your Steam Buddy if preheating is necessary. Then, apply the Mighty Putty as instructed on the wrapper. Use Zorbeez to clean up any excess putty on the surface of the pipe. Finally, after using your Six Shooter to make any last minute adjustments, inform the CWI that your ready for a QC check. He can use his Engrave It tool to sign off on the work.
After a day of rolling around under that nasty pipe, Lint be Gone will remove any pesky lint balls from your coveralls. Just use some Oxy Clean Power Balls in the wash to insure a perfect clean!!
Geez.....What would life be without Billy & all hie wonderful products? :-) S.W.
"I'm going off the rails on a crazy train..." (Crazy Train, Ozzy Osbourne, Blizzard Of Ozz LP)
