Up Topic Welding Industry / Technical Discussions / Rust Inhibitor
- - By gibster Date 08-05-2001 12:31
How can acetone cleaned ER70S-2 or ER70S-6 be protected from rusting without affecting weldability?
Parent - By - Date 08-05-2001 13:05
I assume you are talking about the filler wires themselves. In this case, you should not need to do anything special because they are usually copper coated to prevent corrosion.
Niekie
Parent - By dong won oh (*) Date 08-06-2001 04:55
After cleaning the wire, we are recommended to vacuum seal the wire to prevent rust during storage.
If you have problem of rust during welding(1 day or more), I would like to recommend to heat the wire feeder(specially desinged feeder).
Dong Won Oh
South Korea
