Up Topic Welders and Inspectors / Welding Equipment Classifieds / Two continental 163 motors
- By uphill (***) Date 07-05-2008 19:05 Edited 07-05-2008 23:49
Have two 163 motors complete with all electronics. Photo is motor out of 1980'sTennant sweeper 1640 hours ran nice, downdraft carb,down exhaust, distributor, did compression check found 98-102 dry and wet(put a capfull of marvel oil to do wet test). Spark plugs and pistons look good with do deposits.The bellhousing and flywheel are on in photo but will be removed as they are special for a hydrostatic drive. This engine comes with remote oil cooler. Other engine is out of Airco welder. It is stuck, got water in exhaust pipe, should have good parts . I may be tearing this one down to make sure it has value.  $750 for the pair   Located by Minneapolis MN can load or drop at trucking terminal.
Uphill
dave@hughesphoto.com
763 389 3417  eves and weekends
Attachment: IMG_2932.JPG (0B)
