I am a Welding Engineer for a company who out-sources 100% of their fabrication work. For any given project, we might have 10 or more suppliers working on various weldments. These suppliers will submit their welding procedures and NDE procedures for review and approval. Depending on what they are fabrication I may get 2 WPS’s or 20 WPS’s to review from each supplier for that project. Typically, we have 3 or 4 projects going on at one time. As you can see the amount of WPS’s can add up very quickly. The suppliers are located around the world. I have suppliers in the USA, Korea, and Canada just to mention a few.
As you can imagine the welding procedures are generated using various off the shelf software packages and homemade packages (i.e. Access). The procedures are sent to me via e-mail in PDF or TIF format and by snail mail. Once they are reviewed, they are stored in paper format in a filing cabinet. What I would like to do is to be able to have all my suppliers send their procedures via e-mail in any format, be able to open them for review, make comments to them (if necessary), once reviewed store them electronically in a database. In doing so I will be able to retrieve them for the next project, search for specific WPS’s, update the WPS’s when the Rev number changes. I should be able to track weather the WPS’s have been approved or rejected, and what project they are for (since I have multiple projects going on). Obviously, these are minimum requirements. Is there any software available that would allow me to do this? I have worked with Access and have developed some small databases, but time does not allow me to develop something of this magnitude. Any help or suggestion would be greatly appreciated.
