By -
Date 08-31-2001 19:48
Depending on your exact configuration, microfocus x-ray may work. We use it to perform radiography of tube to tubesheet welds of shell and tube heat exchangers. Here the configuration is similar to what you explained, (Partial penetration groove weld) except that the tubes do not enter at any strange angles, and they are probably smaller than the pipes entering your header.
It may be worth your while to look into this.
Niekie
