Root pass, I stand corrected, the High Freq. box won't work plugged into the SA-200 outlet. You need to find a outside source for the AC power. You can plug in to bldg power or to a small generator with AC power outlets. Then you make up pig tails that go to the High Freq box from the welder. Then you hook up your ground and welding cable coming out of the box to the work. Also hook up TIG whip to welding cable, and your argon to your bottle. You might want to check this out.
