Hello again Drake181, I just went to one of the sites that lists some of the Lincoln wires and their shielding gas requirements, confusing as hell. I looked at this site and you have to very carefully follow the exact wire description to verify whether this wire will allow the use of multiple gases or specifically a straight CO2 application. Check this out for yourself and see if it is indeed the correct wire/gas combination. Best regards, aevald
EDIT: you will need to scroll down quite a ways to find the Lincoln Ultracore 71, there are a few different Ultracore descriptions, all of them list the E71T-1, yet they have different additional descriptions following the initial numbers. Which one do you have?
http://www.dot.state.oh.us/testlab/applists/misc/Electrodes/electrodes3.htm
