Up Topic Welding Industry / General Welding Discussion / Lincoln add on pulser for TIG
- - By Root Pass (***) Date 07-25-2008 04:09
Did Lincoln ever make an add on pulser for TIG machines like the Miller PC 300? Can you just change the plugs on a PC 300 and have it work on a Lincoln product?
Parent - - By DaveBoyer (*****) Date 07-25-2008 05:40 Edited 07-26-2008 04:22
Weather or not You could interchange them depends on what ohm range the machine controlls are set up for. Short answer is probably not, but if You changed the background amperage pot to whatever the Lincoln machine needs You may be able to make it work. The other issue is system operating voltage. If both are 115V no problem, but a Miller 14 pin plug has 115V & 24V where a Lincoln 14 pin has 115V & 42V. You will have to study the schematics for all the equipment involved and figure it out for Yourself.
Parent - - By Root Pass (***) Date 07-25-2008 05:49
Thanks Dave. I thought Lincoln would have made one but I havn't seen one.
Parent - By sbcmweb (****) Date 07-25-2008 18:40
Neither have I. Pulsers are overrated, as far as I'm concerned anyways. I just use "poor man's pulsing" Stomp that foot pedal!. S.W.
