ziggy,
If you contact the nut/bolt mfg and ask them about this, they recommend trying to avoid welding their product to anything altogether(ask me how I know this). The AISC also recommends against welding of HS fasteners. We have had a few blind connections but we didn't use a HS fastener for the final connection, the A307 bolts(A36) were just for erection purposes only and the joint was then field welded as designed.
I too would love to have the oportunity to see/review a qualified procedure for welding HS bolts/nuts to structural steel.
Unlisted base materials(not listed in Tables 3.1 and 4.9) shall be approved by the EOR(see 4.7.3).
