Up Topic Welding Industry / Technical Discussions / Base metal repairs
- - By ctacker (****) Date 07-29-2008 02:40
I'd like to hear some comments on repairing base metal (A36) and the effects of repairing A 2" plate numerous times. (welds and repairs are E71T1 wire, 100%Co2)
The reason I ask, we have a large positioner with a 12' table and it gets dogs welded on and scarfed off and the plate is repaired then goes through the cycle again! this happens on average 12-15 times a year!
Parent - - By hogan (****) Date 07-29-2008 14:01
is the 2" plate preheated each time its gets welded
Parent - By ctacker (****) Date 07-29-2008 14:05
They are supposed to be, but since i dont work 2 shifts, its hard to say what goes on at night.
Parent - - By ctacker (****) Date 07-30-2008 02:41
It would seem to me that welding on a plate many times would eventually have adverse affects on the steel. if anyone has any links or comments on this it would be appreciated!
Parent - By DaveBoyer (*****) Date 07-30-2008 04:40
I would expect that after enough of these cycles that the surface would become dished from each weld contracting as it cools.
