Hows it going everybody I got a couple of questions for you guys again on pipe.It is in the 6g position smaw. I am running 1/8" 6010 root in second gear 80-120 and about 50-55 on the fine current the machine is an sa 200 seems to run ok sum times and other times it seems to put its self out at about the same arc length,also when you are tying in to a tack do you usually run over the tack and keep going or do you stop and start again at the other side of the tack. When start at the other end of the tack I usually have a key hole there from ending the tack but when I go to start the root I pause for a second to fill it in, but on the inside of the pipe you can see that it filled in but not all the way. What is the proper way to do this without burning through,and 1 more question tonight for all of you when starting at the botom of the pipe do you guys use a whip or stringer movement from 6:30 to vertical. I have read that you should not use a whip fro 6:30 to vertical but after that you should use the whip till 12o'clock.This is going up hill. I forgot to ask if you guys grind your root or do you run a hot pass( if so do you use 6010 or 7018 for hot pass.I have been doing root pass than grinding flat that 2 pass with 3/32 7018 one fill and one cap
sorry for rambling,
Thanks for any help, Elliott
