OK, so its not exactly for the chickens, but they do ride on the equipment. I'm doing some training for a chicken processing plant. To all the vegetarians out there, I hope you were not offended by my attempt at a little humor. The material is 10 gauge stainless angle and tubing, they are using the Tig process. Does anyone see anything wrong with welding down when making the vertical welds on structural material used for assembly line frames, conveyor frames, and just general use worktables?
Thank you for your time and replies.
Louis
