Pipewelder_1999, Pipelayer:
Pipewelder; You make a good logical case as to your proposed interpretations of the quoted QC-1 paragraphs. You have a convincing command of the English language and probably would have made a very convincing case to the Certification Committee when this part of QC-1 was being prepared in Subcommittee. I will bring this argument to the Subcommittee meeting.
In the Subcommittee deliberations, we considered other wording, but, for legal reasons, and to conform to the language standard that we use, and the graphic identity standard that we use, and to conform to the AWS Definitions, ETC., ETC., ETC., AND just because that wording was there in the " Strawman" wording at the time of voting by both the Subcommittee and the Main Committee, the wording you see is what you get.
Wording aside, The intent of the Committee is made clear to you now. The CAWI cannot work alone. He failed the test. There are those who did not fail and are CAWI's simply because they do not have enough experience or education to complete the qualification to be a CWI. The only reason we have the CAWI right now, is for those people.
I would rather see some more testing, and give anyone who can pass the additional testing, get the certification, even if they have no experience at all. However, it is impractical for AWS to give a national examination in a reasonable classroom environment, and make the testing relevant and comprehensive enough to assure some minimal level of competence and ability. So, like many other professions, experience, training and education are required prerequisites. I would love to have a "Peer Review" system that would determine everyone's competence and abilities. Who could afford it? Look at what it takes to get a NACE Coatings Inspector Peer Review.
I compared the pass / fail number to the graduates at med schools and the USMA, West Point, just to show that every profession that has a licensure examination or titular examinations has a has a cut off score. If you pass, you get the license. If you do not get the passing mark, you don't get the license. It is generally not considered "unfair" to have a cut off score!?!?! I think it is kind of scary that the man who got a 65 in med school can hang out a shingle as soon as the ink is dry on his state license, yet the man that got 64 cannot. However, we can't have a sliding tier of "Almost a Doctor", or "Almost a Lieutenant", or "Almost an Ensign", or "Just Barely Passed Nurse". It doesn't work It could not be fairly administered as a "System".
I have met a few incompetent CWIs. Some are incompetent because they work for inspection companies that do hit and miss spot inspections, and do not inspect before, during and after.. I am lucky that I am with a company that sees the project through from beginning to end because we work for State DOTs and other Government agencies. I also have a supervisor who reviews my reports and visits me on the job and counsels me when I an deficient. (I Work for Pennoni Associates) When I worked for myself as a consultant, I had to continually walk away from clients who wanted me to perform selective inspections and write specially crafted and worded reports, so they could convince the owner that everything was hunky-dory. I worked with one client pretty steadily for three years, and one day I was sent to a subcontractor where they were welding TYK connections with short circuiting GMAW, no Qualified WPSs, no qualified welders, and really bad welds. I refused to write anything that would help them get past inspection requirements, and told the client that he could never use me like that again!!! I haven't gotten any more work from him. I know that the Port Authority of NY & NJ gets between 30 and 70 phony CWIs and CAWIs (who cut the "A" out of their stamp) every year. I can't get the Port Authority to send me the evidence, because they have a policy against it. (I am a member of the Ethics Subcommittee and I would love to bring charges against those people.)
As for CWIs who fall into the "general incompetence" category, "Incompetence" is not a violation of our Code of Ethic and code of practice. It is not a violation to make a mistake, or even lots of mistakes. It is not automatically a violation of the Code of Ethics to miss bad welds or miss checking out one side of a part, or signing off a piece (that you accidently did not inspect,) by mistake. Some of the activities you listed that may be performed by a CAWI without direct supervision may or may not be violations. It depends on the circumstances.
Many CWIs who fill out WPSs don't seem to know the difference between "specification" and "classification". That may make them incompetent, if they are writing WPSs for a Nuclear plant, but not else where in general. The Certification Committee knows that WPSs and WPQRs and Welder Testing and WPQR Testing are areas where we need to do some more testing and training for the CWI Program. The B-5 Qualification Committee and the Certification Committee will be doing a gap analysis and address this in the near future.
Our system is not perfect, but it has worked pretty well for thirty years, and the Committee is always consireding improvements.
What about the questions?
Is the meaning of the sentance relative to CAWI's a restriction? Is then it not a restriction for the CWI's performing SCWI work ?
I can see no "legal reasons" that the statement for a CAWI cannot say what it means "A CAWI must work under the direct supervision of a CWI or SCWI".
Our entire ability to communicate is based upon words and common understanding of how words are joined to make sentences. The above sentance I made is very clear. However the statement in the standard is similar to statements for CWI's and SCWI's in its structure.
If your response represents the commitee, what about a CWI who performs the duties of an SCWI. I would think that that has to be addressed. Does it say what it says or say what it doesn't say ? If what you are telling me about the CAWI is true, then I have violated the rules of the code. I have performed the duties of an SCWI while being CWI Number 90041071, 98060641 and 07010011. If the wording means the same. Those are the numbers you need.
I have no idea what strawman wording is. I would just expect people that I assume work with codes, standards, and specifications to have the ability to document something in a manner that the meaning is clear without making assumptions.
If the CAWI paragraph has a different meaning than the paragraph for the others, my ability to read and understand "AWS Wording" may be faltering.
If that had ever been a CWI test question, how was it worded? That one question could have been the difference between being able to continue inspecting (Complete Failure or CWI) or not being able to inspect ANY MORE (CAWI)
Par 4.1 t hru 4.3 CLEARLY state what each inspector type shall be able to do. No restriction is placed on any other duties. Only a minimum.
Para 4.4 states the same as it is read. Nothing in its wording indicates otherwise.
If anyone has EVER lost a job due to interpreting PARA 4.4 as a restriction on what you can do, I think legal action would be warranted. It is clearly eiter a poorly written document that should not be used in matters related to someones livelyhood, OR it is being interpreted incorrectly.
I see that you are on one of the committees. Therefore I would think that with all of the information here, the committe stands that para 4.4 wording is not to be interpreted in a manner similar to the preceeding paragraphs under the same section titled "Functions of Certified Personnel".
Is that a true statement ?
This whole thing is extremely troubling. When I indicated I was open to correction, I felt there would be some written statement somewhere that clarified this. Something I had missed in the code. Yet I am still no longer convinced.
I figured a few more would enlighten me to my inability to understand the written code. I will prepaere a formal request for interpretation and send it in so I will at least know I officially unable to understand the QC1 standard.
I realize that the idea that a CAWI cannot inspect without a CWI has been around for years. I just don't see it in the standard. Kinda like downhill welds are weaker, weave beads fall apart, and you have to take a SS test to be qualified for SS GTAW.
Maybe as I read over some more responses, I will come to know what a fool I have been reading something into t he code that was not there. Please post em up.
Gerald Austin
CWI (maybe),
Chairman, Austin Household Child Welfare Fund
CoChair, Austin Household Animal Welfare Fund
Pipewelder_1999
There is possibly nothing wrong with your proposed "A CAWI must work under the direct supervision of a CWI or SCWI". wording. Your "ability to read and understand "AWS Wording" is not faltering. There is a lot to be said for your suggestion. As I said in an earlier reply, I am going to present you idea to the Subcommittee.
HOWEVER, there is also NOTHING wrong with the wording as it exists today. It appears that you believe that the wording "...under the direct supervision of a SCWI or CWI within visible and audible range,..." somehow does NOT constitute a restriction. To me, it is like you do not want to read the whole sentence and accept it as one idea. If you are an AWS CAWI, the AWS does not allow you to perform the inspections without tight supervision.
Basically, if you are a CAWI, you flunked the test, (unless you are one of those persons who just do not have the requisite experience / education combination). If you do not want to abide by that restriction, and do not feel that it is fair, do not become a CAWI. You can use the B5.1 and become a company certified inspector (as long as you are not a CAWI.
If you were on the QC-1 Certification Subcommittee, you could also make direct proposals and arguments for a change in th wording. If you were on the B5.1 Qualification Subcommittee, you could propose and argue for different restrictions, responsibilities, and duties.
4.4 The CAWI shall be able to perform inspections,
visible and audible range, and as defined for the AWI as
in AWS B5.1, Specification for the Qualification of
Welding Inspectors. It is the SCWI or CWI, however,
who has responsibility for certifying that welded assemblies
conform to workmanship and acceptance criteria.
There is no restriction in the wording for the WI / CWI that prevents him from performing the duties of the SWI / SCWI. This lack of restriction is one of the items that reduces the average CWI's desire to become an SCWI. The CWIs that I talk to often ask "Why Should I" I already do all the things listed in the B5.1 as a CWI. Why should I spend the money for a certification that isn't required anywhere, and doesn't really qualify me to do anything new?
As for your statement; "If anyone has EVER lost a job due to interpreting PARA 4.4 as a restriction on what you can do, I think legal action would be warranted. It is clearly either a poorly written document that should not be used in matters related to someones livelyhood, OR it is being interpreted incorrectly. I disagree. Since when would it be unreasonable for any certifying organization to place restrictive wording on it's product? If your employer wants you to be a CAWI and work alone, that is the employer's right and it is up to you to decide whether you want to take the chance on getting caught. Of course, in the US of A, almost anyone can sue anyone over anything, so I would agree with you there.
Paragraph 4,1 through 4.3 do not spell out restrictions, but In my opinion, the Paragraph 4.1 does spell out a restriction. While I cannot speak for the whole Committee, I personally wrote the "visible and audible range" wording and the Subcommittee and the Main Committee voted for it. It was clearly the intent to restrict the CAWI.
I look forward to your formal RFI to the Committee, although I seem to remember that there is already an "Official interpretation" on this subject.
Joe Kane
I am having a hard time understanding whare I am missing the differences we have regarding meaning however I can see how that
1) The paragraph can lead the reader to believe that the inspecor(CAWI) must be supervised .
2) You have been personally involved with the wording and active with the committees, I have not.
I concede that you must be correct in what the intent is regardless of the wording and that the wording must have been good enough to convey the idea because that is what the majority of people say that it means to them.
I will continue to read it and I think it will come to me. The comma between the ...perform inspections, under... may mean something that I am not comprehending. I apologize for leading any astray and I appreciate the opinions of everyone.
Thanks
Gerald Austin
Pipewelder_1999
On thing is clear, the Subcommittee could always make any issue clearer after the publication of any document. HGtx and you have made a good argument for that on this issue.
I begin to see your points clearly, than I re-read the entire section 4 of the QC-1 document. Then, I remember that the abilities and functions of the AWI are set by the B5.1 Qualification Document. Then I go back to the QC-1 certification document and I find that it clearly says what AWS is certifying you for, and what the limits of that certification are. The two documents complement each other. I then revert to my original defense of the document as written.
Then, I realize that I have an Institutional Bias, and that this MUST have some influence on how I read it. I also know that more voices and more ideas in committee usually make better documents. I may not be able to "see the forest for the trees". However, it is possible that you may have an outsiders bias to the issue and you might not be able to "see the forest for the trees." We in committee often get sucked into wordsmithing modes that try to condense what is said in any given paragraph. Then six months later It gets condensed again. The institutional memory tends to forget why some sentence was left in there originally and the revision leaves out or re-condenses the paragraph once again. After publication, an issue pops up from the outside, and "We know what we meant, Why can't you see that?!?!?! Of course, on the other side of the coin, someone outside often does not like what is written, and raises and issue based on wordsmithing. Now the Committees are often obliged to revisit what they thought was put to bed and settled once and for ever! That is the nature of document and standards production.
I too will re-read this issue several more times before I come to terms with what should be done.
Joe Kane
By 803056
Date 08-08-2008 03:48
Edited 08-08-2008 03:58
This would be an excellent exam question; to make sure every candidate understands that accepting the AWS credential, be it the CAWI, CWI, SCWI, etc. binds the holder to the code of ethics whether the project/employer has a requirement for the AWS credential or not.
The very next question should address the limitations imposed on the job functions a CAWI can perform and what conditions are attached.
I've been involved as an instructor for the CWI seminars and I know this subject is discussed. Maybe it needs to be discussed in a little more detail to make sure everyone understands what is involved when one becomes a CAWI, CWI, or SCWI.
Joe, maybe the restriction could be written to be more ironclad. Something like; "The CAWI can only work as an assistant to either a CWI or SCWI that is present, in the same room, and within auditory range of the CAWI."
The code of ethics can be written to clarify the point that the CAWI, CWI, or SCWI are bound to abide by the rules of conduct and code of ethics if they accept the AWS credential whether QC1 is a contractual or project requirement or not.
Maybe an article in Inspection Trends would be helpful.
You made some good points Gerald.
Joe,
Pipewelder has brought up a good point that has got me thinking. If a CAWI is in violation of the code of ethics for performing the duties listed in B1.5 as requiring a CWI or SCWI, then is a CWI in violation for performing the duties listed for a SCWI. Many of the items listed in B5.1 are regularly performed by many of the CWI's I know as well as myself.As an example the following are listed in B5.1 as SCWI duties:
Procedure Qualification:
(7) develop welding procedures
inspection:
(8) prepare visual inspection requirements
(9) prepare NDE requirements
(10) report investigation results of quality inspection disputes
(11) prepare destructive testing requirements
safety:
(2) develop safety procedures and policies
quality assurance:
(2) develop quality assurance plans
(3) prepare base material control requirements
(4) prepare weld consumable control requirements
(5) prepare audit and surveillance plans
(6) prepare documentation control requirements
Project Management:
(3) prepare weld inspection bid specifications
(4) prepare purchase specifications
(5) determine vendor capacity and capability
(6) select vendor
Training:
(4) develop and provide a training program for the WI
(5) provide technical leadership for welding inspectors
(6) develop quality assurance training program
(7) verify implementation of quality assurance training
(8) provide guidance and direction to inspectors for maintaining and upgrading their individual qualifications
Evaluation:
(2) evaluate WIs performance
(3) perform inspection results trend analysis
From what I'm reading, I would assume (dangerous to do) that if it applies to the CAWI then it would also apply to the CWI. Is that correct? Thanks for you input.
There is nothing that says a CWI must work within visual or audible range of a SCWI when performing tasks that a SCWI Shall be able to perform.
thats my take on it!
Just wondering, because you replied to my post, if this was indeed a reply?
sorry, I started to write a reply, got called away and accidently hit the enter key. Joe said the same thing I was gonna say but in different words!
Hogan
No! The only restriction is in paragraph 4.4 for the CAWI. There is no stated restriction in the QC-1 for the AWS CWI. (Except for the QC-7 restriction) The Restriction for the CAWI is because most of them failed the test. Those that passed the test but still do not meet the Experience and Education combination requirement still are not qualified. How could AWS reasonably allow a person who failed the test to act substantially the same way as a real CWI? It doesnt even sound reasonable.
There is no wording that says the CWI cannot write WPSs and WPQRs. It just says that AWS is only certifying the SCWI to have the ability to do so.
If you were an EIT would you be allowed to pretend you were a registered PE and sign off calculations? Thus AWS says that the CAWI has demonstrated some skills, but is still not qualified.
The reason I said that the CAWI is the only person in the world that cannot inspect a weld without close supervision, is because the AWS does not have control over what everyone else does or other programs allow. We do control the CAWI, so if the CAWI wants to inspect welds, he must have someone supervising. He cannot be a CAWI and claim he is acting as a Level 2 or a "Special Inspector". If he is a CAWI, the restriction applies 24 / 7. If he officially surrenders the CAWI credential, he can do whatever he wants, or whatever his boss wants.
Joe Kane
Joe,
I see what your saying about 4.4 and can follow that. This is how I have interpted it. So I guess what my next question would be is when is AWS B5.1 table 1 applicable?
There is NO wording that says a CAWI cannot test a welder, write a WPS, witness a PQR either, Is there ?
well, not that this comment is worth a hill of beans, but the statement within visual and audible range, could be a long distance with invention of internet video phones, im not saying I would condone this but someday someone may try this.
MDK
As long as there is a CWI or SCWI supervising, and signing the document or countersigning the documents.
There is no wording that says a CAWI can't be an olympic athlete. There is no AWS prohibition against a CAWI doing paint inspection. There is no AWSprohibition against the CAWI winning the lottery. There is no AWS prohibition against the CAWI performing welding or practicing law.
Well there should be!!
[Edit] All of the below refernce to certifying a welder is in ralationship to the above indication that a CWI or SCWI must be present[/edit]
There is ABSOLUTELY NOTHING that indicates a CAWI cannot certify a welder or any of the other related tasks.
Is the exclusion of "cerfify welders" in relationship to a CAWI an indication that it cannot be done? If it is then my previous points related to a CWI performing [Edit]SCWI[/edit] duties comes into play.
I keep thinking "I MUST BE AN IDIOT" because when I read the standard, I see nothing that prohibits anything besides inspection and that has some holes that I must somehow come to grasp with .
But to indicate that the CAWI cannot perform some other duty seems really odd.
Please t ell me exactly WHAT paragraph prohibits the CAWI from certifying a welder? MAybe he cannot perform the inspection on the weld (I'm still working on that in my brain), but there is nothing to prohibit the certifying of a welder. If the fact that those duties are calledd out for the CWI or SCWI, then we need to re visit my current certifications.
Am I the only one that thinks there is something odd? Maybe again I have missed something. There is only indication that a CWI is the person responsible for certifying a welding inspection. There is NOTHING about certifying a welder.
It is my opinion that theree is some extremely conflicting ideas being conveyed on the forum versus what is actually written in the code. I may be the one out of my mind. Who knows!
Gerald Austin
i don't know much about this argument, but where i work cawi are only allowed to do visual weld inspection with the cwi present. that way you can see they are performing proper inspections and be readily available for questions they may have. as far as giving weld test i think they can do that to, or anything a cwi does how else are you going to learn your job without experiance. but all results should be signed off by the cwi or scwi. the cawi is basically a trainee nothing more. i read on the section for scwi it was for the person in a supervisor or manager spot. most cwi i know work by their self or with a cawi, they are not in charge of other cwi. that is one of the duties of a scwi.
Individual companies may very well address the issue in various ways. However they way it seems to be interpreted, if the QC manager in a company goes to take the CWI exam and fails (CAWI), he/she is no longer authorized to certify welders unless he/she chooses to NOT be a CAWI.
Again, I find no text in the QC1 standard that indicates this is the case however just because I don't see it, doesn't mean it does not exist.
