In South Africa this term is used for a process whereby cracked castings are repaired through drilling and tapping the cracked sections and pulling them together with small studs. A rather intricate operation, which when done well will render a casting "leak proof" after the repair.
By its nature, it is not practiced widely anymore, due to the advancement of welding technology. I do believe however, that there will be some companies around that still do this. Personally I would try the welding route first. (But then, being a welding engineer, what else would you expect?)
Niekie
the problem of welding castings is that is it difficult to get to the 'end' of the crack. The thermal input has a tendency to pushthe croak out further making the repair useless. A combination strategy has however been effective. - Find the ends of the cracks, drill then out (so they don't get longer, THEN weld the joint instead of weave the joint.
