Up Topic Welding Industry / General Welding Discussion / MillerMatic 180 with auto set
- - By KENNY629 (**) Date 08-09-2008 18:45
DOES ANYONE HAVE THIS MACHINE? AND IF SO, DO YOU LIKE IT? =)
Parent - - By Billyjoe (***) Date 08-17-2008 00:01
it one of the best little millermatic I ' v ever own ,you use argon with it ,makes good welds ,little spatter, you can also use a spoolgun with it ,the gun is about $225.00 ,,,,good machine ,,,,,it will hold a 10 lb row of wire.
Parent - By KENNY629 (**) Date 08-17-2008 03:25
I was told that u can either use gas no gas works ether way......
