![](/mwf/attachments//avatars/9282-5576.jpg)
Hey CamaroBarbie,
You may have success with this procedure:
If there is a slight protrusion of the bolt above the surface, take a cutoff wheel and cut a slot across the center, deep & wide enough to engage a heavy screwdriver.
After cutting the slot, while the stud is hot, spray on generously some PB penetrate and allow to sit an hour or so.
Warm the area surrounding the stud, and with a heavy screwdriver & light hammer, tap the driver while turning the stud. I have removed hundreds of broken bolts & studs with this method.
Hope this may help you.... Good luck..... Denny
