If I remember correctly, the lowest anticipated service temperature on the vertical axis, the material thickness is the horizontal axis, and the curves, A, B, C and D are the factors that have to be considered. If your material is grouped as a B material, and the temperature and thickness plot above curve B, you do not have to do impact testing. If the plot of temperature and thickness fall below curve B, you do have to perform impact testing.
