Up Topic Welding Industry / Technical Discussions / WPS & PQR SOFTWARE
- - By grhamltn Date 09-12-2001 13:08
Does anyone out there use any software to assist in generating weld procudure specs and qualification documentation? If so, which ones are generally accepted for the industry standard? I'm learning on a steep curve, and spend significant time thumbing through code, etc.
Thanks in advance!
Parent - By jfolk (**) Date 09-13-2001 15:13
I use C spec welding engineering soft ware (Weldoffice). Our actual use now is Weldspec and WelderQual. It allows you to develop WPS,PQR and WPQ for ASME Section IX as well as AWS D1.1. I am very satisfied with it and the technical support is excellent. Go to www.weldoffice.com for more info.
Parent - By stan ford (*) Date 09-19-2001 16:52
1. Download Weldspec and Welderqual from cspec.com
2. Call their tech-support to get started.
3. Have a finished PQR, WPS and WPQ within minutes.
( See http://www.cspec.com/sample )
