Up Topic Welders and Inspectors / Education & Training / Capping
- - By juve11 (*) Date 08-15-2008 02:45
How do you cap the bottom (overhead) of pipeline using 5/32 5+.
Parent - - By dbigkahunna (****) Date 08-15-2008 16:41
Note: This is not a smart a$$ answer. You weld the bottom, just like you do the top, just upside down.
BABRT's
Parent - - By juve11 (*) Date 08-16-2008 04:03
how is that
Parent - - By dbigkahunna (****) Date 08-16-2008 15:27
If you are using a side to side on top, then do a side to side on the bottom. If you are doing a circle on the top. then do a circle on the bottom. Travel speed will vary as you hit the sides, but keep the travel speed on the bottom, about the same as you do on the top.
Just upside down.
BABRT's
Parent - - By juve11 (*) Date 08-16-2008 16:35
what do you think the heat difference from toop to bottom should be
Parent - - By dbigkahunna (****) Date 08-16-2008 20:58
None. You weld the bottom just like the top. Same heat same motion.
Parent - - By Billyjoe (***) Date 08-17-2008 02:32
go get you some pipe an play with it ,
Parent - - By juve11 (*) Date 08-17-2008 04:29
got some but having problems with undercut on the bottom.
Parent - - By rockin d (**) Date 08-17-2008 10:27
probabaly to hot , & going to slow , try horse shoe motions ( coming back towards you ) & just tap the bevels .
Parent - - By juve11 (*) Date 08-17-2008 15:53
thanx rockin
Parent - By rockin d (**) Date 08-18-2008 22:26
anytime
