Up Topic Welding Industry / General Welding Discussion / have a lincoln classic lll sa-300-,WILL NOT WELD
- - By Billyjoe (***) Date 08-16-2008 00:59
I can run a grinder ,but can't strick an ark ,(will not weld )  trouble shooting my problem any an all help
need.
code ##10156
serial ## C1960500340
model sa-300-TMD27
Parent - - By welder_Bob (**) Date 08-16-2008 02:59
I have had the same kind of problem twice before with my SA-250.  Check the rheostat and the wires that go to it.  Also check the remote switch to see if it is stuck or bad.  If it is stuck in the remote position you will not get an ark if the remote isn't hooked up.  That all I can think of that is easy to check.
Parent - By Billyjoe (***) Date 08-16-2008 03:49
thanks I'll check it out
