Code-Red,
/quote Lawrence/
"...The fellas have covered everything here... I"m sure you don't like the answers, but your hearing them from from the best professionals on the planet and not some hack pal who uses pop-can solder he bought at Home Depot or the Farmers market."
/unquote/
This is pretty true.
Thus it's normally unneeded to add something.
However, just as a very short remark to this from my side, based upon what Jim Hughes has posted.
There is a patent granted in Germany to the MTU company (Maschinen und Turbinen Union).
They have "developed" the so-called AGL-power source or process respectively, (A = Aluminium - GL = Gleichstrom) which stands for GTAW Aluminum Welding under Helium with DCEN polarity. Although it is idle to discuss if they were the "inventors" of DCEN GTAW Aluminum under Helium, the process itself is quite interesting.
It allows actually to weld greater wall thicknesses e.g. cast aluminum motor blocks without the need to preheat or remove them prior to welding. This is due to the intensive and tight geometrical area of heat input. Its being used in a wide field where submarine- or in general large ship motor blocks have to be repaired (e.g. in case of cracking).
As far as I know its being accomplished with great success without preheating the heavy AlSi-cast block.
I have tried to find two reports about the use of the process being contained somewhere in my trade journal collections, but I beg your forgiveness, I haven't found them and it would take too long to continue the search - although I know they are there.
I have tried to google the articles but the only document I found is a kind of leaflet from a German company (MAUDERER) using this process (patent) to repair large walled AlSi cast motor blocks without preheating or removing the block or to weld large wall thicknessed Aluminum constructions. I'd like to attach the document here, but I apologize for that it's written in German.
However, it doesn't matter, since I think the hint coming from Jim Hughes, additionally to what's already been posted by the other experts is worth Gold. I mean the usage of Helium - patent to and fro - might be worth a try at least.
You have to consider however, that the arc ignition might make some problems when using Helium, since it needs a higher voltage. But it depends upon the power supply and if so you might try striking the arc.
Helium finally could make sense in your case...
Just my humble opinion.
Thanks and best regards,
Stephan
