Up Topic Welding Industry / General Welding Discussion / dodge cab and chasis air bags
- - By tightline11 (**) Date 08-24-2008 21:06
hello,  i was wondering if any or ya'll know  where i  can  get me  some air bags  for  my 02 dodge cas and chasis   all i  can  find  are the  ones  for a  dually and not  a cab chasis???  thank  for the reply
Parent - - By Cactusthewelder (*****) Date 08-24-2008 23:00
Air bags are not worth the money. They leak bad. A friend of mine who owns a truck shop in Canton, texas told me about Timbren Overloads. They add 9000 lbs. to your normal capacity. Airbags only add 5000 max. Timbrens are made from solid rubber. NO LEAKS !. Air bags cost 500-900 Timbrens cost 300 installed. They are the best for the money.
Parent - By 52lincoln (***) Date 08-24-2008 23:38
yea they are the s**t.they really work.my friend got some.and i'm fixxin to put them on my truck as well.
Parent - - By texwelder (***) Date 08-25-2008 00:12
So when the frame makes contact with them do they give at all or is it like you have no springs
Parent - - By shorthood2006 (****) Date 08-25-2008 00:22
i have tembrens on my truck
Parent - By texwelder (***) Date 08-25-2008 01:34
So how do they work?
Parent - - By tightline11 (**) Date 08-25-2008 02:16
hey cactus,
heres  my problem  or  this is whats going on  with my  rig  and  i  dunno if  those  springs will fix  my problem   here  it is............   my  rig  heavy on  one side   will those  springs level it out  or  will it  just be stiffer  with the same lean?????? see what  im talking bout?????   thanks again  for the help   those are  some good looking  springs   i  wish i  knew they  worked to solve my problem
Parent - By texwelder (***) Date 08-25-2008 02:34
Yeah good ? are they what some call helper springs
Parent - - By Cactusthewelder (*****) Date 08-25-2008 10:05
They should level it out. They are not helper springs. Here is a number that you can call and ask an expert. 903-567-2691 ask for Chad or Johnny.
Parent - - By mody454 (**) Date 08-25-2008 23:25
hey ill be running thru canton tomarrow is that a shop number or home number id like to throw those on my truck if they can get me in and out quick
Parent - By Cactusthewelder (*****) Date 08-26-2008 00:12
That is the shop #
