Up Topic Welding Industry / Technical Discussions / welding 1 inch thick 6061 T6 Alm Material
- - By 1fastguy (**) Date 08-25-2008 19:49
We are working on a project for a speaker manufacture. They are large grids made from .500 to 1 inch thick 6061 T6 Alm. They are going to test break the first grid. We have done similar projects like this using 4043 Filler Rod in GMAW it flows and welds real good but it is not as strong as 5356filler rod.  Would it be woth switching to 5356 filler rod for this type of application because of the higher shear strength 5356 rod gives you?
Parent - - By Joseph P. Kane (****) Date 08-26-2008 02:49
In my opinion it would be better to weld 6061T6 with 5356 from a mechanical testing point of view.  If architectural considerations or anodizing, are required, 4043 is still the best.
Parent - By 1fastguy (**) Date 08-26-2008 15:32
That is the direction we are proceding. The part gets painted.
Parent - - By DaveBoyer (*****) Date 08-29-2008 04:50
    Joe, I agree that 5356 will have better mechanical properties, but it is better as far as weathering and anodising color match as well. 4043 darkens in weather exposure, and doesn't color match when anodised, but I prefer to weld with it when I can.
Parent - By Joseph P. Kane (****) Date 08-30-2008 15:10
Dave
You are correct.  4043 is not good for anodizing.  I don't know what I was thinking.   I have had architects and  fire commissioners require me to use 4043 because it was nice and shiny and looked nice when first welded.  I have tried to explain that the weld would tarnish.  Of course, the fire trucks were always being polished, so as long  the welds were smooth, the truck looked good.  Part of the problem is that I wasn't a good enough welder to make the 5356 wet out as nicely as the 4043.
Joe Kane
Parent - - By bozaktwo1 (***) Date 08-26-2008 16:47
Definitely use 5356, as long as no PWHT is required.  But if you have to bring the material back to T6 condition, 5356 will crack out.
Parent - - By 1fastguy (**) Date 08-27-2008 15:47
no worries, no PWHT is required. Thanks
Parent - By Kix (****) Date 08-28-2008 14:31
4643 gives good mechanicals in 1/2" thick on up and still has the same characteristics of 4043.
Parent - By EVWELDER (**) Date 09-01-2008 04:40
Sounds like you are maybe making something called speaker bumpers? Anyway do you plan to use GMAW because if you do 4043 filler wire will be your best bet 5356 filler wire does not run all that great with GMAW with my experience I have built some things for speaker manufactures in the past sounds similar to what you may be building with 1" 6061-T6.
