The "Hand-cuff" systems works well for production work, a metal stamping company I worked for used them on all the hand fed presses in conjunction with doubble buttons. They were "Possun Pul Back" brand, if I remember right. We used them on rather long stroke fast cycling punch presses. The operators do need to be sure that the cables aren't tangled with a fast press, if they are it really yanks on the wrist. The buttons should be placed such that there is plenty of slack in the cables at the bottom of the stroke whith the buttons down.
At the auto frame plant they did not use the pull back system, only doubble buttons. On multiple operator presses there was a doubble button stand for each operator, the activation buttons were in enclosures so You couldn't press them if You fell against the stand. There was an emergency shutdown button on top of the enclosure. These stands were not mounted to the machine, they were on a length of cable so they could be moved to an appropriate position for the operators safety and convinience.
