Up Topic Welding Industry / General Welding Discussion / Help Please
- - By CK Welding (**) Date 09-03-2008 22:54
Just got a job that is testing on 2" and 3" haven't ever tested on such small pipe.  The company is supplying, it is 5p bead and HYPI all the way out.  First off what size rod would they most likely give me.  I would be comfortable with 3/32 on the 2"  but is it likely they will give rod that small or will they want me to test with 1/8 on the 2".  Secondly, how does HYPI rod run in comparison too 5P+.  Is it hotter, coolder, about the same,  Faster, slower, stuff like that.  Any help would be apriciated.  Not used to pipe this small. THanks
Parent - By sjkelly328 (**) Date 09-04-2008 01:10
more than likely they will give you 1/8 5p. if they do alot of 2 inch they should have some 3/32 around. in my opinion the hyp runs colder it will stack alot better than the 5p
Parent - - By showmewelder (*) Date 09-04-2008 02:14
hey man,well hopefully they will just have u use 1/8 inch 5p, but if ur comfortable using 5/32 id use 5/32 hypi once u get pasted the hot....so whats the company ur goin to work for??
Parent - - By CK Welding (**) Date 09-04-2008 02:24
Northwinds,  The line is like 12" and 16".  I don't know why they are testing on such small pipe but it can't be that hard.  I prefer big inch pipe because thats what I am used too,  I will just have to give it a go! The worst that could happen in I bust out and go somewhere with a test I am more familiar with.
Parent - - By showmewelder (*) Date 09-04-2008 13:43
i hear ya man,,well good luck to ya,,where did u say they where gonna work ya at
Parent - By CK Welding (**) Date 09-05-2008 21:02
The job is in lysite / lost cabin Wyoming
