Aluminum pipe is most likely extruded. The plate is rolled. Any porosity, should any exist, in the base metal would most likely be "flattened" during the extrusion or rolling operations. I doubt there is porosity in the base metal.
I can imagine a situation where the film interpreter, being inexperienced, could mistake spatter for porosity. The difference would be obvious to an experienced film interpreter. Spatter would appear to be slightly lighter than the adjacent base metal and the porosity slightly darker than the surrounding base metal. Both would be rounded and possibly the same approximate diameter.
