Up Topic Welding Industry / General Welding Discussion / MM 250
- - By chris99669 Date 09-06-2008 19:01
I recently purchased a MM250 and would like weld aluminum. What would be the best way to get started with the MM250. Is there a module to hook up a spool gun I can buy?
Thanks in advance.
chris
Parent - - By sbcmweb (****) Date 09-06-2008 19:23
If the MM 250 you have was an X model, you can attach the spool gun directly to it. If not, there is a kit you can purchase from Miller PN 042607. This will easily install in your machine & you can plug the gun directly in after that. The Spoolmatic 30A is going to run you $450-700 used depending on where you get it from. Keep a lookout on ebay & you can probably get one for a reasonable price, $500-600 is around average. If you try using the regular gun you have to run AL wire, you will have lots of problems & get frustrated fast.
Good luck on it. Steve.
Parent - - By chris99669 Date 09-06-2008 19:43
Thanks for the help I will need the module. I only have the 250.
Parent - By sbcmweb (****) Date 09-06-2008 19:58
Any weld supply who is a Miller distributor can order it for you. S.W.
