I found it here
http://www.aisc.org/Content/NavigationMenu/AISC_Certification/2006_Building_Standard/2006_Building_Standard.htmThis is what was refrenced:
The Fabricator shall have the latest editions available and
be able to demonstrate the ability to work to and meet the
requirements of:
* AISC Steel Construction Manual, which includes the
following specifications, codes, and standards:
* AISC Specification for Structural Steel Buildings1
* RCSC Specification for Structural Joints Using
ASTM A325 or A490 Bolts1
* AISC Code of Standard Practice for Steel Buildings
and Bridges1
* ANSI/AWS D1.1 Structural Welding Code--Steel
* AISC Selected ASTM Standards for Structural Steel
Fabrication2
The Fabricator should also have the following references
readily available:
* ANSI/AWS A2.4 Symbols
* ANSI/AWS A3.0 Terms and Definitions
* AWS Welding Quality Assurance Guideline for Fabricators
(WQAG)
* SSPC Steel Structures Painting Manual, Volume I,
Good Painting Practice
* SSPC Steel Structures Painting Manual, Volume II,
Systems and Specifications
* AISC Seismic Provisions for Structural Steel Buildings1
* AISC Detailing for Steel Construction
