Up Topic Welding Industry / Technical Discussions / comparision
- - By dlc Date 10-09-2001 05:13
Dear sirs,
I'm in search of a table which compares the properties of Cast steel with Cast Iron and structural steel which are utilised for the manufacture of hydraulic Presses.
This is urgently required as the procedure handbook on arc welding indicates the comparision between cast iron(not alloyed) and mild steel (not alloyed) only, whereas I'm looking for a comparision as stated above.
it is requested to send me the details/help me at the earliest.
with warm regards
DLC
Parent - By pdweldor (*) Date 10-09-2001 14:00
Try www.ductile.org. This is the ductile iron society, they have some very good propeties data and design recommendations.
Regards.
